Originally Posted by nemesisinfinity
(Post 706619)
it has the factory clamp down, im pretty sure it only gained 1 tooth but i could be wrong? iv read about people slotting the brackets to get a little bit of turn to them also?
I also noticed the scanner you recommended says it doesnt do ABS my wifes car has an abs light that comes up every so often, any preference on one that will do ABS? i dont want to keep borrowing the shops scanner so im going to have to order one b4 i can take it any further Gotta remember that the communication protocols on Ford, GM, and Chysler are not all the same, and have changed over the years. Since 2006 they have all now standardized on CAN protocol, but each manufacturer's enhanced PIDs are not standardized and can even vary from year to year. As an example, Dash Command is the only phone app I have that will do enhanced PIDs on my 2006 Pontiac G6 GTP (first year of CAN protocol). Car Gauge Pro will connect to it in generic mode only. Torque Pro will not connect at all. This is all through the same OBD2 adapter and phone. The Windows software has no problem with the G6, but it's $150+ software. I believe that even newer GM vehicles have yet another OBD2 hurdle, but I'm not up on that. Remember, the car manufacturers have no motivation to make their enhanced PIDs work with any equipment other than their own. If an outside manufacturer of equipment or software wants them, the enhanced PIDs are for sale. I believe this is why some software/apps (Dash Command) charges you extra for them. The ones that don't charge you, apparently have figured out enough of them to be useful (Car Gauge Pro, Torque Pro, etc) - at least on certain vehicles. Yep, slotting the bracket or replacing with a small block chevy distributor hold down was what I was going to suggest - but only if you can read cam sensor retard. Once you have an adjustable distributor, just monitor cam sensor retard while turning the distributor. Be sure to rev it above 2000 and back to idle before doing a final read on the cam sensor retard. If your SES light is off, you're not feeling any misfires, and you want to know if you need a CASE relearn - then monitor the misfire counters on a scanner while pulling plug wires. Counter should increase rapidly for the disconnected cylinder. If it does this, then misfire detection is working fine and there is really no need or advantage to doing a CASE relearn. Good luck! |
Thanks for all the info!!! Really appreciate it!!!
The one I used was pretty extensive and had the ability to be ugdated. I would love to buy one like the scanner I borrowed, but it looks like it maybe little out of my price range. I will let you know once I order me a scanner or I'll just give in and borrow it again. The SES light has gone away and I don't notice a miss anymore! I should be able to get a hold down relatively easy. Thanks again, I will pop back in once I have an update. |
(Post 706747)
Originally Posted by LesMyer
(Post 706795)
Please let us know how you end up. We always like to know!
It came from a 97 s10 I no longer have access to I took pics of the numbers off the block though Engine light came back on today, but scanner is supposed to arrive tomorrow atleast! |
This is what I'm getting from the scanner
SES was on cause O2 sensor https://cimg0.ibsrv.net/gimg/blazerf...9196a4cafb.png |
Alright, lets get that Cam sensor retard adjusted to zero and then we can work on any other problems that are still there. Is this Blue Driver on your phone?
Na I got dash command and the bafx scanner
I read there can be 15° of leway just moving the distributor around with the normal clamp. I'll try that tonight |
(Post 706912)
I read there can be 15° of leway just moving the distributor around with the normal clamp. I'll try that tonight On a side note.... Now that you have the BAFX OBD2 adapter, if you are doing Android you should be able to use Car Gauge Pro to (at least) read/clear the ABS codes on your wife's car (if not more). What car does she have? It doesn't hurt to have more than one OBD2 software available to you and Car Gauge Pro is pretty cheap. |
She has a 03 ford escape
Its for android I'll grab that app as well!!!! I do have the old engine that I could maybe modify it's hold down to be the way I want? I assume it would involve grinding off the 2 "prongs" that go around the distributor shaft? I also used dash commander to make a log of me driving about a mile through town I was reading that the cam retard is connected to my injectors pulsing, so could this give me a code relating to my o2 sensors and fuel trim? |
(Post 706920)
Its for android I'll grab that app as well!!!! I do have the old engine that I could maybe modify it's hold down to be the way I want? I assume it would involve grinding off the 2 "prongs" that go around the distributor shaft? I also used dash commander to make a log of me driving about a mile through town I was reading that the cam retard is connected to my injectors pulsing, so could this give me a code relating to my o2 sensors and fuel trim? Yes you can grind the prongs so you can turn the distributor, but difficult to get it off the distributor unless it's removed from the engine. Actually that's what I did to mine instead of the bolt hole thing (but other people seem to prefer the bolt hole method). The PCM does use the position from the cam sensor to sequentially pulse the injectors. I have never heard of cam sensor retard being off causing O2 sensor codes, but I suppose it is possible since yours is off quite a bit more than is usually seen. This is why I suggested that we fix the cam sensor retard before worrying about anything else. |
| All times are GMT -5. The time now is 11:46 AM. |
