Front cover oil leak
Hello
Fired up the new engine in my blazer.
Have a leak at the front cover to oil pan.
How hard is it to remove the front cover.
Or is there anyone out there who knows any tricks to fix this problem.
Thanks for the help.
Generally speaking (since you haven't provided any vehicle specifics), you must loosen the oil pan allowing the front to drop down as well as pull off the water pump to get the front cover off.
Thanks I have a 97 s-10 with a 4.3 liter.
Cast pan.
How hard is it to drop the front diff on a 97 s-10 Blazer. 4.3 liter v6
I need to drop oil pan to fix a oil leak.
Cast pan.
Last edited by swartlkk; 09-28-2010 at 08:17 PM. Reason: Combining Consecutive Posts - Please edit your post to add additional information/questions if another member has not yet replied.
The cast pan is going to make things difficult. It doesn't flex like a stamped pan. You will have to loosen the whole pan up to drop it down.
I would try loosening it first before removing the front diff...
Chevy33
04-17-2013 04:22 PM
