-   -   Front cover oil leak (https://blazerforum.com/forum/engine-transmission-35/front-cover-oil-leak-49636/)
Blazer Steve 09-28-2010 07:56 PM
Hello
Fired up the new engine in my blazer.
Have a leak at the front cover to oil pan.
How hard is it to remove the front cover.
Or is there anyone out there who knows any tricks to fix this problem.
Thanks for the help.
swartlkk 09-28-2010 08:00 PM
Generally speaking (since you haven't provided any vehicle specifics), you must loosen the oil pan allowing the front to drop down as well as pull off the water pump to get the front cover off.
Blazer Steve 09-28-2010 08:13 PM
Thanks I have a 97 s-10 with a 4.3 liter.
Cast pan.
How hard is it to drop the front diff on a 97 s-10 Blazer. 4.3 liter v6
I need to drop oil pan to fix a oil leak.
swartlkk 09-28-2010 08:16 PM
The cast pan is going to make things difficult. It doesn't flex like a stamped pan. You will have to loosen the whole pan up to drop it down.
I would try loosening it first before removing the front diff...
