-   -   front diff, I need help (https://blazerforum.com/forum/engine-transmission-35/front-diff-i-need-help-63538/)
00blazer13 09-27-2011 06:58 PM
2000 s10 blazer 4x4. Changing front diff outer shaft seal and bearings. Passenger side was leaking, so I am doing both sides. Is there a trick to getting the driver side shaft out of the diff case? Or do i need a bigger hammer?
NVANZEE 09-27-2011 07:18 PM
put a piece of 2x4 on the backside of the shaft from under the truck. Then a few good wacks with a hammer should pop it loose.
00blazer13 09-28-2011 05:38 PM
Thanks, I got it apart.
Little Roober 09-28-2011 06:11 PM
Hey. I need to fix the same thing, but only the driver's side. How big of a project is it? I just need to replace the seal. Is it worth $120 to have a shop do it?
00blazer13 09-29-2011 06:47 PM
Not a bad job if you have tools. I rented a ball joint separator. A pry bar and a thin piece of wood got my axle out. I don’t c paying a shop for this job. This is my first time doing this job. Ask yourself, how much is my time worth? Good Luck!
Little Roober 09-29-2011 07:54 PM
Well, I have all weekend since work's rained out tomorrow. I may take it on. And maybe bed liner the rockers and such too. I need something to keep me busy! :icon_wink: Thanks for the tips.
98blazin 09-29-2011 08:25 PM
i did my driver side front diff seal last month.
i bought the seal allready pressed in the diff plate for 55$cnd at the gm dealer.
took about 1 1/2 hr to do it. was pretty simple/easy.
