-   -   frozen radiator need some help (https://blazerforum.com/forum/engine-transmission-35/frozen-radiator-need-some-help-76354/)
bobby099 01-07-2013 01:51 PM
well i have my blazer in the garage for the winter, i always used 50/50 so i start it every 2 weeks to make sure everything is in working order. this week i had the hood popped open and my coolent was slushy but after 5 minutes i was getting warm heat just not hot. should i drain my radiator and use straight antifreeze?
1sttimejimmyowner 01-07-2013 01:59 PM
No you dont want to use straight antifreeze maybe about 60/40 ratio and get an antifreeze tester to find out what the freezing point is after you fill it.I know they are less that $10 and pretty self explanitory to use.
bobby099 01-07-2013 03:02 PM
yeah i bought one of those yesturday the reason im asking is i just bought another jug of 50/50 but im wondering why its still kinda slushy like its got water in the radiator i dont have heat in the garage but its not super cold out its suppose to warm up this weekend maybe ill just change it before it gets cold again.
grizzstang 01-10-2013 03:28 PM
It it is freezing I would say that you have more water in your system than you think. I would drain the system and add new 60/40 ratio antifreeze as suggested above. Stop buying premixed antifreeze as you are being charged for water. Mix it yourself and test it before you put it in the rad.
bobby099 01-10-2013 06:08 PM
i already changed it out to 60/40 now im having heat issues
rexazz2 01-10-2013 07:11 PM
if you got slush you never had much antifreeze
Never used pre mixed doesnt really allow you to increase strength
I was told that straight antifreeze will turn to gel BTW
Park on as steep uphill incline as you can find
drain rad
refill slowly with engine running ,heater on
dont rush to cap the rad ,keep an eye on temperature gauge
top off rad when normal operating temp is reached and cap
Make sure you change fluid out in catch tank its also watered down
1sttimejimmyowner 01-10-2013 09:59 PM
What does your engine temp get to after running a to being fully warmed up?Your thermostat made need to be changed.
