Fuel Issue
Old Aug 12, 2007 | 11:51 PM
andym's Avatar
andym is an unknown quantity at this point
Default Fuel Issue
I have a 1996 S10 Blazer 4.3 W Engine, Car won't start sometimes, put fuel in the throttle body and it starts and dies, checked fuel pressure and have 50psi, we replaced the spider assy, camshaft sensor, temp sensor(at first it only did this after running awhile), crank sensor, rotor, cap and plugs. Engine runs like a top when it starts. I am lost now ,shows no codes ,no check engine light, where do I go from here besides the scrap yard? Help!
Old Aug 13, 2007 | 01:59 AM
ggwash21's Avatar
ggwash21 is an unknown quantity at this point
Default RE: Fuel Issue
50psi on fuel pressure test? i believe it should be around 120psi..... When you turn the ignition on do you hear your fuel pump kick on? i would bet its the fuel pump... My old 95 did the same thing... and i ended up replacing the fuel pump and ran like a champ...
Old Aug 13, 2007 | 06:00 AM
Fuel pressure should be 55-60psi, not 120psi... YIKES!!
If you turn the key to the 'ON' position and wait a few seconds for the fuel system to prime, does it start easier? Do you find that it doesn't start after it sits for short or long periods of time?
Also, when you say that it doesn't start, will it just crank over and over without firing? Will it fire, but not catch? Please provide a bit more information as to your symptoms...
Old Aug 13, 2007 | 11:27 AM
andym's Avatar
Tried turning the key on and off a few times to allow pump to prime but still no-go, when I say it cranks I mean it turns over but no sign of trying to fire but the fire is there seems like I am getting fuel up to the schrader but then I don't know, started first thing this morning after I let the battery slow charge all nite, then wouldn't start so I figure maybe wasn't getting the voltage I needed so I replaced the battery still no go, just now I checked fuel presure and am only getting 30 psi so I think I am going back to the fuel pump, it is only @ 6 mos. old but it is a Carter and I have been having issues with Carter ever since I started replacing it I think this is the third pump now in 2 years if it weren't for the lifetime warranty I would go with a different brand. I will let you know if that fixes the problem or not. Thanks for letting me vent as I am totally getting fed up with pouring money in this vehicle but it is my wifes and she loves it. ( I hate the damn thing have to spend all my time on it and none on my El-Camino!!)
brian79z
32
Feb 23, 2015 07:13 PM
99bblazer99
Jun 15, 2013 08:38 PM
95jblaze
Aug 27, 2011 03:46 PM
J.R. Clay
Mar 16, 2011 12:33 AM
extreme
Jan 5, 2010 07:29 AM
