-   -   Fuel line question (https://blazerforum.com/forum/engine-transmission-35/fuel-line-question-98034/)
Big'n 10-28-2018 11:30 AM
Fuel line question
1998 gmc jimmy 2 wheel drive 4.3 vortec my stereo has vibrated the the metal fuel return line against the fire wall an rubbed a hole in it.
Oreillys has the line for 100 bucks but on the end at the engine connect side it doesn't screw on it's a quick connect. I'm no mechanic by any means but I think mine screws on. Anyone know for sure ?? An if it does screw on where do I find one ??
thanks in advance
Big'n 10-28-2018 01:18 PM
Napa says it doesn't have much pressure on the return line an to use a repair kit they sell that has the fitting I need They say just cut out the bad spot at use the new line with a compression fitting.
Will that work ?
Rusty Nuts 10-28-2018 01:39 PM
Yes. The return line is 5/16", pump max output is 108 psi, compression fittings can hold that.
Big'n 10-28-2018 02:05 PM
Ok one question. Guy at oreillys says I can use rubber line because it's just the return line. I thinking if I can use rubber why didn't gmc use rubber when they built it
thanks for your help brother
Rusty Nuts 10-28-2018 03:06 PM
Anytime. Rubber does not last as long. If it's raining I'd use rubber for a qiuck fix. Make sure it fuel injection rated rubber and clamps.
Big'n 10-30-2018 05:52 PM
Thanks again Rusty I got her fixed no leaks an holding pressure
odat 10-30-2018 07:03 PM
kind of a stupid question but how did your stereo vibrate the the return line and have it wear on the firewall
Big'n 10-30-2018 07:41 PM
I have 16 12" subs running on 4 7500 watt mono blocks the vibration on the fire wall ate a hole through the return line. Won't happen again though It's wrapped with rubber now lol
odat 10-30-2018 08:21 PM
Do you have a hearing problem yet ---- no ---- just wait lol
AndyBees 10-30-2018 08:55 PM
One day you'll be truly sorry that you didn't protect your ears if you are not doing so now.
Not from loud boom boxes or music, my hearing is horrible. Also, even worse, I have Tinnitus which is caused by
damage to the hair like things in the middle ear. My T never stops... ringing 24/7 for the last 4 or 5 years. And, I've
had T since 1997. It wasn't very bad the first three or four years.
So, protect your ears!
Yeah, the return hose has virtually zero pressure on it. It just dumps back into the tank at the fuel pump........ installed one (fuel pump) in my 95 Blazer today!
