Fuel Pressure Drop
Old May 15, 2012 | 12:57 PM
Darla Smith Garrett's Avatar
Darla Smith Garrett is on a distinguished road
Default Fuel Pressure Drop
Ok, while checking fuel pressure on 2001 Blazer that will not start (tries to after several "tries" but then acts like it is not getting fuel) when key is turned on (not started because engine will not start) fuel pressure goes up to 60 psi, when fuel pump shuts off after prime the pressure immediately drops to 55 psi. Should it do this? I thought that it should hold pressure longer than that.
Old May 15, 2012 | 02:22 PM
50lb_cat's Avatar
It shouldn't drop immediately. If it drops more than 5 psi in 10 minutes you have a problem. Either the filter is plugged, the regulator is bad or injectors are bad. How far does it drop in 10 minutes?
Old May 15, 2012 | 02:29 PM
Will check that when I get home and will post results. Thanks!
Old May 15, 2012 | 04:13 PM
While waiting for my husband to get home so we could check the pressure 10 minutes after priming, I decided just to try it. Started right up!!!! Still starting. Had a slight problem starting if i primed the pump first before turning the key completely over. I DON'T GET IT!!!!!
Old May 15, 2012 | 05:07 PM
OK, this is what is happening. If i let the pump prime before trying to turn over engine, it will not start. If i just turn the key all the way to start the engine without letting the pump prime, it starts right up. Any ideas
Old May 15, 2012 | 07:16 PM
50lb_cat's Avatar
Is it throwing any codes? Black smoke out of the tailpipe?
Old May 15, 2012 | 07:56 PM
No codes, no black smoke. Someone suggested may be a leaking diaphragm on fuel pressure regulator. They said that by priming it that the leak could flood the engine so it will not start. That does make sense. I will pull the vacuum hose tomorrow after priming the pump and see if it has gas in it.
Old May 15, 2012 | 08:21 PM
pettyfog's Avatar
Umm.. there's nothing to pull. It's not a fuel rail system, and the regulator is inside the plenum. You'd have to pull the upper intake to check it. Since you've already seen the leakdown is quick, it's probably a good bet to look.
Old May 20, 2012 | 12:31 PM
Did pressure test. Starts now when primed first. Actually starting great with and without priming. Ok, started it up, got up to 60 psi, while running around 50 - 55 psi. After turning it off, stayed at 50 psi and held steady for at least 10 minutes. Checked it again after about an hour and the pressure has increased to around 54 psi. Guess it is not leaking. Did put Marvel Mystery oil in it Monday. May have had a blockage somewhere and marvel took care of it. Don't exactly know, just know that it is holding pressure and starting great and seems to be running better. We will see!
Old May 20, 2012 | 01:11 PM
50lb_cat's Avatar
The test needs to be done with key on, engine off. Post back those numbers.
Repus J 13
16
Apr 6, 2012 09:37 PM
zjo
Mar 16, 2012 08:03 PM
BlazeOn
Jan 15, 2011 04:45 PM
HHimmy
Dec 1, 2010 01:52 AM
brianroark
Jun 25, 2010 03:14 PM
