-   -   fuel pump (https://blazerforum.com/forum/engine-transmission-35/fuel-pump-9212/)
ubnsmkd03 Mar 8, 2007 11:54 PM
fuel pump
whats up guys?? iam new to this forum i have a 2000 blazer lt that i have for my dd and fuel pump went out... anyone know why these damn things are so much to replace?? it was like over 300 just for pump no labor..... anyone else have any info.... i heard it's common on these things to take a crap tho..... thanks for any info in advance..... mikey
Hanr3 Mar 9, 2007 01:54 AM
RE: fuel pump
Not sure what infomration your looking for.
Yes the newer fuel pumps are expensive. You are replacing everything, the fuel pump, and the fuel sending unit for your gas guage, plus they are pushing considerable more pressure then the old fuel pumps. There is a tag on top of the fuel pump, you need that number in order to get the right part.
Why do they fail, simple, low gas in the tank. These things are cooled by gas, if you are constantly running the tank down to e before refilling it, your reducing its life span. When they get hot, the seals wear out faster. Keep it around 1/4 tank and it will live longer.
Now if your looking for info on how to replace it yourself.
Simple. Get a Haynes manual. If your considering doing this yourself. Post up and I can go into more details. It really simple. Two words of caution. Gas weighs 8 pounds per gallon. 10 gallons of gas is 80 pounds. Gas fumes are highly explosive. An empty tank is more dangerous then a full one.
Dabber Mar 9, 2007 01:02 PM
RE: fuel pump
Defineatly more dangerous but less of a workout LOL
JustBlaze! Mar 9, 2007 02:30 PM
RE: fuel pump
Welcome to the forum. There's lots of information in the forum on replacing your fuel pump. Just do a search on it. Hanr3's write up on a previous post was helpfull when I did mine recently.
I did a short writup when I did mine
https://blazerforum.com/m_66285/mpag..._/tm.htm#66285
ubnsmkd03 Mar 9, 2007 08:21 PM
RE: fuel pump
thanks guy!!!!! you have been very helpful....
