Greg1456 |
07-22-2013 08:21 PM |
Fuel System Leaking - Will Not Relieve Pressure
I have a 2000 Chevy Blazer and at time fuel will start leaking from the vent solenoid that is located over the spare tire. When this occurs the engine is not running. When you loosen the gas cap the leak stops. So far the solenoid valve has been changed and the latest thing was fuel pump. The garage that I took it to told me that GM told them it is a fuel pump problem. Well that did not take care of it and they did not charge me for the pump or any labor. I changed the gas cap and so far nothing until the other day and it started leaking again. Does anyone have any ideas. I am thinking about changing the canister.
