Fuelpump noise
Old Jul 4, 2010 | 01:16 PM
janbhauge's Avatar
janbhauge is on a distinguished road
Default Fuelpump noise
Hi
I need your help, I was out driving today in my Blazer 1998, it was very hot 30 C' (celcius) about 86 Farenheit, and after 30 minuts the motor stoped. I have noticed the last couple of days that I have been driving with it, that the noise for the fuelpump were getting louder, and today this stop...
After the motor stopped I startet the motor and drove again, but only for 3 minuts then it stopped again, then I startet again and turned around and drove back home about 10 miles without any problems....
Does I have a loose contact on my fueltank, or maybee a fuelpump problem, or maybe a radiator problem...
I can hear the fuelpump when the motor is running is that normal?
Old Jul 4, 2010 | 01:36 PM
4x4blazerguy's Avatar
Smile
Originally Posted by janbhauge
Hi
From my experience a noisy fuel pump is the first signs of fuel pump failure. My guess is you are in need of a fuel pump. But to confirm check your fuel pressure, should be 60 PSI.
Old Jul 28, 2010 | 05:38 PM
benbikai's Avatar
benbikai is on a distinguished road
i changed my fuel pump about last year and after that it made a loud whining noise all the time i just changed the fuel filter and it went away but it sounds like your fuel pump is going out you usually shouldnt let your car go below a quarter of a tank but if it keeps dying like that run it until it runs out of gas cause the fuel pump is alot easier to change when your tank is empty
larsipan
Dec 20, 2013 09:55 AM
Irish07
Oct 31, 2012 06:04 PM
Chrismacster
Apr 2, 2009 06:57 PM
ltown21
15
Dec 1, 2007 06:42 PM
Jhop16
Feb 4, 2006 10:39 PM
