-   -   Gas pedal sticks upon passing (https://blazerforum.com/forum/engine-transmission-35/gas-pedal-sticks-upon-passing-38636/)
Rickc46 12-30-2009 09:29 AM
I have a 95 T-10 Four door 4X4 VIN W Blazer.
When I put the pedal to the metal to pass, It sticks down. I disconnected the kick down cable and left the throttle cable and it does not stick. Are there any known problems with the Transmission kick down cables???? Thanks Rick.
oisinirish 12-31-2009 07:03 AM
It's possible that the cable may be frayed causing a hang-up or it just may be dirty?
WolfPack 12-31-2009 10:22 AM
could just be carbon buildup in the throttle body. Mine used to stick in the form of being hard to break loose from position 0 moving to accelerate. Once broken free it moved fine but once back at 0 it would stick.
Take a look at your throttle body and get a can of TB cleaner!
