Gas smell in cab of truck
I have a 96 S10 extended cab 4.3 Vortec V6 I am getting a strong smell of gas inside the cab of my truck. Truck is running great except for the smell of gas. Only had one trouble code and it was intermittent code for the right Bank O2 sensor. Can anyone give me an idea where to look to address this problem? Everything I have read is pointing to the fuel pressure regulator but I don't want to spend money I don't have to if that's not the problem. Any suggestions would be very helpful, Spike 318
From what I've picked up here, one of the first checks to do is measure the pressure in the fuel lines. The gauges for doing so can be borrowed from autoparts stores. Look for threads as to how long the system should be able to stay pressurized at at what pressures.
Thank you I'll get me a gauge and check it
See the link in the bottom of my signature block to do the fuel pressure/leakdown test Christine is referring to. Follow Captain Hook's instructions.
Originally Posted by rockp2
(Post 690347)
Originally Posted by SPIKE318
(Post 690349)
I guess I'm stupid I don't see that link
(Post 690347)
(Post 690345)
| All times are GMT -5. The time now is 10:41 AM. |
