gearbox screwz
gearbox screwz
Hello guyz,
Last week I've mounted the rebuilded gearbox on my chevy (blazer 4.3 1992 4WD. 1GNDT13Z2N2207291).
Unfortunately the gearbox was dismantle by the guy I bought the chevy... And I miss some fixing screws for the gearbox to the engine case.
My sister who lives in florida asked a chevrolet dealer for the screw but he said that they don't have them to sell because they are standard bolts.
But!!!!... with metric I will for sure found what I need but with imperial measures I don't understand anything...
So here is my question...
Does someone knows the size of each of the 6 bolts who fix the gearbox on the engine case??
thanks a lot for your help.
Well i have a bunch of them laying around, I have to run up the parts store in about a hour, I will take 1 of them with me so i can tell you the size.
Ok the bolts you are looking for are "3/8 x 16 coarse x 1 1/2 standard-thread bolts", And just incase you dont have your 3 torque converter bolts they are "M10 x 1.5". Hope that helps you out
WOW... I thanks you very much my friend. It is great!!
I will searching for them.
My sister in florida used to have an offer from the Chevy-guy. 80$ for the bolts.
It seems to be a little bit expensive isn't it??
D'you think it is ok??
http://www.fastenal.com/web/products...u=19933&ucst=t
Last edited by swartlkk; 05-26-2010 at 04:38 PM. Reason: **Combining Consective Posts** - Please use the EDIT feature to add information to your post if another member has yet to reply.
Thats way to much money, You can go anywhere that sells bolts near you, Give them the size i gave you, And buy the 6 bolts you need for $5 to $10 us dollers.
I'm in France Mate... it is not so easy to found this kinds of bolts...
But I'm on the way to...
thanks very much
thanks very much
