gm cpi conversion
gm cpi conversion
can anyone tell me where i can buy the conversion kit for cpi to mpi for blazer 01
CPI was from 92-95. Your engine is an SCFI engine.
Try searching for "MFI+upgrade". The part numbers are posted.
its well worth doing, i have done it to all three of my trucks. Just dont by the bracket they claim is different for the mpfi style, because its not i have done them on mine and all my friends and have never needed it yet.
Some brackets have in fact been different, not having the same clearance built into them than the newer style which can cause the injector lines/wires to rub against the bracket. The only ones I have replaced the bracket on were the 96-97 engines. These are the only ones I have found to be different.
If you were able to ensure proper clearance between the lines and the bracket, then it shouldn't be a problem, but if things move around, you could end up with a very nasty leak inside the plenum.
Hmm guess i got lucky then i just did my 96 last week used the same bracket as well as my 97 bravada back in 07. Sorry for the slight misinformation on that subject. my 98 jimmy i did last summer that was the only one that looked a little different guess i know why now the bracket was changed after 97.... learn something new everyday i tell ya
thanks but where do i buy the kit
There are A LOT of places that sell it. Google the PN and see what turns up. Be proactive!
Williamsb7181
05-09-2013 09:49 PM
NC93BLAZERLT
16
01-04-2010 11:08 AM
