-   -   Guys I need help (https://blazerforum.com/forum/engine-transmission-35/guys-i-need-help-98466/)
88blazerzac 12-30-2018 05:16 AM
Guys I need help
I have a 1988 chevy s19 blazer 4x4 and I got a rebuilt transmission I put it in hook everything up and at first I only got second I messed with the sifter and got one or two gears no park or reverse really need help guys
Transman304 12-30-2018 05:42 AM
Are you sure the linkage bracket on transmission is not installed upside down? Can you send a picture?
88blazerzac 12-30-2018 11:18 AM
88blazerzac 12-30-2018 11:21 AM
And it won’t shift properly only got first didn’t mean to say second
Transman304 12-30-2018 06:28 PM
Take out the rod from shifter then Unbolt the bracket and turn it over so the arm is pointing down. The put shifter rod back in place. Give that a try. Good luck.
christine_208 01-02-2019 01:05 AM
Following (because I always learn something from Transman304!)
