hard shift into gear and from 1-2
Old Nov 1, 2012 | 09:14 PM
miner69er67's Avatar
miner69er67 is on a distinguished road
Default hard shift into gear and from 1-2
i have a 96 awd s10 blazer with a 95 bravada transfer case i baught it with a bad tcase. ok so here is the deal i have no codes the valve body has been rebuilt with sonnax parts i have a new epc i have swaped the shift solinoids as well as the rest of the electronics but i still have a very violent 1-2 and when it shifts into forward and reverse is also hard i am running out of reasons for this kind of behavior any help would be greatly appreciated it is a 08/96 so it doesnt have the ground problem
Old Nov 1, 2012 | 09:41 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
Is your MAF (mass airflow sensor) plugged in or having problmes? When i had mine unplugged for a while the same exact thing happened and i had no idea why. Plugged it back in and everything was golden
Old Nov 2, 2012 | 04:06 AM
Ok i wil check it im pretty sure its plugged in does anyone have the steps to diagnose a bad maf
Old Nov 2, 2012 | 02:27 PM
tmnc78's Avatar
tmnc78 is on a distinguished road
If you figure it out PLEEEEEEEEEEEEASE let us know what it is. I have been dealing with this since i bought my Jimmy a year ago. So far i have changed the TPS, cleaned the MAF sensor twice, new EPC soleniod, new 1-2 acummulator and new Sonnax pinless forward accumulator piston and fluid and filter. Nothing has worked so far though im sure it has something to do with valve body.
Old Nov 2, 2012 | 07:06 PM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
I know mine did this just before the shift solenoid went out. belive it was the 1-2 solenoid. I lost 1st and 4th when it went. But maybe it is an issue with the iac? that's just a wild guess.
Old Nov 3, 2012 | 09:25 PM
cucv30's Avatar
cucv30 is on a distinguished road
Sounds like you are running full line pressure. That usually happens when you get an 1870 code which is caused by the TCC regulator valve bore being worn. They usually work right when cold but after they warm up then they lose oil and it throws the EPC to full line pressure. A good scanner should tell you where the trouble lies. Watch the EPC percent reading and see if it drops when you get on the gas. Should be at around 58 to 60 at idle.
Old Nov 5, 2012 | 06:01 PM
tmnc78's Avatar
I have no CEL and the reader i have shows no codes. Do you need a special reader for trans codes? Also mine is a 2000 model i thought they had fixed the TCC regulator issue by then.
Old Nov 5, 2012 | 06:40 PM
xgiovannix12's Avatar
No special obd scanner is needed to pull codes... Hows the truck running? excellent good slugish lately ?
Hows the Tranny fluid ? Clean dark LOW over filled ?
Old Nov 6, 2012 | 09:13 AM
tmnc78's Avatar
I'd have to say it runs great besides the shifting, if anything maybe a little sluggish in first. Fluid levels right on, was just changed along with TPS, EPC solenoid and new foward and 1-2 accumulators and cleaned MAF.
Old Nov 11, 2012 | 01:47 AM
i have a upgraded valve body allready i acualy dug into it to check every thing over and it all looks good swapped all the solenoids all the electronics in the tranny im at a loss here about to junk this piece of **** but it is such a nice truck i just cant bring myself to sell it and get had on the price
