Has anyone ever painted Vortec valve covers, plenum or other plastic bits?
I'm bored today.
I've broken loose and removed, or drilled out all my broken bolts and studs, cleaned my throttle body, IAC bore, and entire lower manifold. Now I'm waiting on the postal carrier (fuel injector upgrade kit and a few other minor bits today) and the Fedex guy (water pump, front cover, heater hoses, bypass hoses, fan clutch today and/or tomorrow). I was looking at the ugly black plastic bits and thinking, those would look better painted. Has anyone done this? Did you use engine paint? or some paint specifically for plastic? Any primer at all? Primer for plastic? Engine primer? |
1 Attachment(s)
Originally Posted by Racer_X
(Post 665551)
I'm bored today.
I've broken loose and removed, or drilled out all my broken bolts and studs, cleaned my throttle body, IAC bore, and entire lower manifold. Now I'm waiting on the postal carrier (fuel injector upgrade kit and a few other minor bits today) and the Fedex guy (water pump, front cover, heater hoses, bypass hoses, fan clutch today and/or tomorrow). I was looking at the ugly black plastic bits and thinking, those would look better painted. Has anyone done this? Did you use engine paint? or some paint specifically for plastic? Any primer at all? Primer for plastic? Engine primer? https://blazerforum.com/forum/attach...ine=1464883528 http://i1260.photobucket.com/albums/...psuxmciryi.jpg |
Thanks, Les.
I wish I'd done "aluminum" on the plenum piece. I did the plenum, the intake air piece over the throttle body and the front cover yesterday. I used a traditional Oldsmobile color for my white Olds Bravada. I'll post pics when everything is done and installed. I used a primer I know bonds well to plastic, followed that with the "engine paint" primer and engine paint color coat, with a engine paint clear coat at the end. The valve covers are primed, and have white color coat down the lettering. We had a big storm that interrupted me yesterday. I brought the valve covers in and got most of the lettering masked (to keep it white). I'll color coat and clear coat them today, probably after I put the front cover, water pump and other new "front" parts on (new hoses, belt, belt tensioner, etc.). I might also paint the air filter box top piece. I haven't decided on that yet. |
1 Attachment(s)
Alrighty then. Lots of black paint on black plastic. Wow, I was half expecting to see some painted to match the exterior colors, or at least "Chevrolet Orange-Red" or "GM Blue".
If mine wasn't white, I would have come as close as possible to exterior color. Since mine is white, and I don't like trying to keep a white engine clean, I went with something more traditional. |
nope, same color as the body
1 Attachment(s)
(Post 665593)
If mine wasn't white, I would have come as close as possible to exterior color. Since mine is white, and I don't like trying to keep a white engine clean, I went with something more traditional. https://blazerforum.com/forum/attach...ine=1464896533 |
2 Attachment(s)
I wasn't saying there was anything wrong with black. I guess I just expected more variety.
Thundering and spitting rain again here. So I'm back inside. Here's a pic of my front cover and intake air piece. https://blazerforum.com/forum/attach...1&d=1464898502 Metallic gold. Not quite "Oldsmobile Rocket 350 metallic gold," but close enough to remind me of the first car I ever bought with my own money (a 1973 Olds Cutlass Supreme with the Rocket 350 engine). |
Looks good!
| All times are GMT -5. The time now is 08:27 AM. |
