heavy coolent leakage
i have a 96 4 door 4x4 4.3L v6 vortex blazer and have a bad coolant leak. the leak is on the top of the motor on the drivers side twords the front of the motor. i went to get a bottle of bars leak to try a quick fix. at the time i couldent find the leak. befor i bought it i asked to use there test gauge. hooked it up i pump it to about 15 lbs and could actuly see the leak. it was spouting up from right behind the a.c pump. it dosent piss out hard enough to acutly see it spouting up when its running. but it leaks a good enough to realy piss you off an **** up ur drive way.it might not hade very much anti freez in it the past week and it did get to like zero degrees maby 1-2 days this week if that tells you anything. please help i have very low funds this ression is kickin my ass. thanks' ant
RE: heavy coolent leakage
Sounds like an intake gasket leak. Use 'search' and there are plenty of posts regarding the repair procedure.
is that the only thing it could be??
No, but based on your description (and without having a picture of it to look at), I would say it is the most likely. If you could post a good picture of the leak, it would help.
| All times are GMT -5. The time now is 09:46 AM. |
