Help....blown head gasket or blown intake gasket..?
Ok guy's I just replaced my fuel pump in my 2001 limited edition trail blazer 4.3 which went well but after getting the truck running I put it in gear to drive and it shook a little then cut off then I noticed it had ran hot in a matter of minutes. I popped the hood and checked my water and anti freeze and it was dry...My friend checked my oil and it looked like coffee with heavy cream! My friend think's I have a blown gasket some where but I can't really afford to get it fixed. My question is can I use a gasket sealer to fix the problem and if so which one is best to use?
That stuff doesn't work, you would just end up clogging the radiator.
Most likely a head gasket change is what you're gonna have to do. |
Originally Posted by limited edition 1
(Post 468322)
One caution, if you drive it like that you will destroy the bearings in the engine. You must change the oil if it is milky. |
But will the sealant work bromanjr
(Post 468366)
ok thx
hopefully it was intake...not that terrible of a job, just takes all day or so if you doing it yourself. it took me 12hrs to do mine. was well worth the cash i saved vs paying for the labor.
| All times are GMT -5. The time now is 10:40 AM. |
