-   -   Help Installing Alternator (https://blazerforum.com/forum/engine-transmission-35/help-installing-alternator-18581/)
ChevyRacing88 03-20-2008 02:13 PM
I aplogize but im jus learning to work on cars...lol...but im trying to install a new alternator and cant seem to get it lose, im comparing my new one to my old and only see 3 bolts holding it in...but its still in there and wont budge...am i missing something???
riceh8r0512 03-20-2008 02:26 PM
RE: Help Installing Alternator
ORIGINAL: ChevyRacing88
Is your belt off? My '98 only has two bolts holding the alternator to the bracket, but the alternator does not put tension on the belt, there is an automatic belt tentioner on these blazers. Once the two bolts are out it's kind of a struggle to get the alternator out, but a little bit of prying will pop it out, I had a little trouble getting mine to come out, it is kinda tough. But then it's just a matter of pulling the wire harness out and unbolting the battery cable.
ChevyRacing88 03-20-2008 02:32 PM
yeah i got the belt tensioner off....
swartlkk 03-20-2008 03:17 PM
The lower mounts can be tight. I used a pry bar to get the alt out of my old Bravada.
ChevyRacing88 03-20-2008 03:29 PM
good news is i got it..used a big screw driver to pry it outta the mounts..battery is dead now so its on a trinkle charger...ty for info gents
