Help with replacing tranny fluid on 95 Jimmy
Old May 5, 2009 | 07:33 PM
cage47's Avatar
cage47 is on a distinguished road
Default Help with replacing tranny fluid on 95 Jimmy
So I spent the better part of the afternoon trying to get the tranny pan out without disconnecting any other pieces. And not make a mess (yeah, right) well I can't get it out because it's boxed in by the muffler cross pipe in the front and the tranny cross member in the back. I would have just disconnected the exhaust pipe at the manifolds but those bolts are in there tight. Gonna take some work. And it's a bear to try to get the tranny cross member out. So what would be the best way to get that tranny pan out? exhaust pipe or cross member?
Old May 5, 2009 | 08:01 PM
Been discussed before. The first thing to try is unbolting the transmission mount and jacking up the transmission. That can sometimes give enough room to get it out of there. Be careful not to damage the wiring on the bottom of the valve body though.
If that does not work, then you will need to remove the cross member.
BrinkDiamond
Mar 2, 2014 03:50 PM
ski.dive
Feb 7, 2014 05:18 AM
porkfriedrice
Jul 3, 2013 02:51 AM
tgeorge608
Jul 8, 2009 06:49 PM
DaleA
Jan 13, 2009 08:50 PM
