Hesitates when engine is cold
Old Feb 11, 2015 | 02:34 PM
Justin56's Avatar
Justin56 is on a distinguished road
Default Hesitates when engine is cold
My 99 blazer 130k miles hesitates when its first started up. I changed the fuel pump and injectors all with delco replacements and did a complete tune up delco cap rotor plugs and wires. It only does this if I don't let it warm up and I have no check engine light either.
Old Feb 11, 2015 | 08:41 PM
After the vehicle sets for 10 to 12 hours, and before you start the engine, use a scan tool to compare ECT, (engine coolant temperature), IAT, (Inlet Air Temperature) and ambient temperature. They must all be within a couple of degrees of each other.
Post your results.
Next step is check fuel pressure and leakdown. This link explains: https://blazerforum.com/forum/2nd-ge...eakdown-88305/
Post your results.
mickey_bigdaddy
May 27, 2015 02:01 PM
fraze936
May 15, 2012 10:32 PM
bdtau44
Jan 29, 2012 01:12 PM
thesnowgod
Dec 5, 2007 02:41 PM
O_P_PLaya
Headers, Intake, & Exhaust
Jul 3, 2006 06:14 AM
