| Lawrence Palmer |
03-23-2018 12:21 PM |
Hesitation
ok ill start by saying thing problem started after took it to the mub pit on our last trip bout 6 months ago. ive been going through things to try figure it out. it only happens when I accerlerate hard, if I ease on the gas pedal itdoesnt do it. ive replaced my fuel pump and filter and cleaned out the gas tank thinking there was trash. I got a can of mass air flow sensor cleaner and used that it didn't help. me personly I think its a air issue somewhere as there are some air lines under the hood that aint being used. when we first got it the 4x4 didn't work there was a line that wasn't hook up right I think I swithed the lines and it started working however there is one that was hooked up to the smog pump thing that is now not hooked up thinking I should get a spliter and try hooking it back together so that they both are hooked up.any suggestions will be helpful. thanks in advance for any responces to this issue.
