Hesitation Help Please!
I have a 2000 Chevy Blazer 4.3 that has hesitation. Now its very drastic if the trucks cold and i need to move it quick. I hit the gas and it seems to studder badly or fall on its face then I have to hit the gas more then it lunges and goes when completely cold. It does it until it warms up some and still does it slightly from an idle and that's it. It has new plugs about 6,000 miles ago, wires, distributor, fuel filter, air filter, throttle body cleaned, MAF cleaned all within about 15,000 miles. I had recently put new motor in about 6,000 miles ago but don't remember if it did it with my old motor or not because it did the throttle bod mod along with this new motor. I have a cam and some other minor internal motor work supporting the cam, header back exhaust, a cold air intake, and a tune. She runs very strong other than that hesitation. Ive also checked my trans mounts and everything's good, I thought they could be worn out and could be torquing up but they are fine. Any help please? Thank you!
P.S. It also does start up a little hesitant from the start compared to when warmed up or recently ran a couple hours ago etc. I have a feeling that can relate also
Any other info anyone? This alSo came to mind, I'm reusing the intake manifold off my old motor which also had this problem and as I said it starts a tad funky then Rpms climb as already said. Could it be a leaky injector?
Yeah its the original spider. No i haven't ran that. Ive had some Lucas fuel injector cleaner etc ran through it but anythings worth a try. Can i get that at any auto part store and im assuming its stronger than a normal fuel system cleaner?
pensfan74
14
Sep 17, 2013 10:26 PM
buddanicholson101
Apr 29, 2010 01:19 PM
DSMayo
Mar 15, 2010 07:21 AM
TWINNOTCHBACKS
Dec 5, 2009 06:19 PM
