HM290 Bellhousing bolts...
Howdy...
Anyone know where I can get new bolts for the bellhousing on an HM290 in a base model 1997 Blazer 2door 4x4? I tried most GM parts places and Ebay and Amazon and local parts places and I can't find any help. Don't want to get them from a junk yard, Want new ones. Figured I could just go to Ace Hardware or Home Depot and get some bolts that match, but pretty sure the bolts need to be a certain tempered grade to be mounted on the motor.
Help would be MIGHTY appreciated!
I listed incorrect pitch size of threads in first post. What you will be looking for is M10 x 1.50 x 45mm.
Good luck
Brad.
quick search on amazon showed these.
Good luck
Brad.
I already ordered the other ones on Ebay. I'll order some of these as well. Obliged for the help.
Obliged. Not meaning to get off topic but noticed yer in WV. I'm looking into getting a house with some folks in Charleston in a few months. Main reason I want my Blazer in perfect condition to drive there from Oregon. I hate this place for numerous reason. Maybe I'll see ya around the roads sometime.
Take care.
Take care.
Update...
Got the new bolts but they are not the correct size to mount the bellhousing to the back of the motor. So I went to the Home Depot with the old bolts that fit and they are 3/8"x16 threads. The M10x1.50x45's don't even go into the holes in the back of the motor.
So off to get the correct threaded bolts again. Luckily bolts are expensive, just a slight set-back and annoyance. The incorrect bolts are going in the miscellaneous bolt bin.
