How to change that !@#$% front transmission oil ring?
Old Jun 11, 2011 | 08:08 PM
freddyjones39's Avatar
freddyjones39 is on a distinguished road
Default How to change that !@#$% front transmission oil ring?
I have just pulled my transmission out of my 4.3L 1991 Blazer due to a leak. The front oil seal looks to have seen better days, and is clearly leaking. I have been trying for some time now to get that thing out, but to no avail. Could somebody please give me a couple pointers or tips on getting it out. I heard they are hard, but wow! I'm hoping there is something that I am missing.
Old Jun 11, 2011 | 08:38 PM
xgiovannix12's Avatar
theres a seal puller out there . never saw one but i need to do the same job on my truck
Old Jun 11, 2011 | 08:58 PM
chris015's Avatar
the few ive done were also a pain in the yang yang. I always ended up ripping them up with channel locks and taking the thing out chunks at a time. Getting one in is just as fun. When you try to knock in one side the other side pops back out. I used a piece of pipe and a hammer. placed the pipe around the ring and tapped on it. I dont remember what size it was.
Old Jun 11, 2011 | 09:01 PM
yea sometimes its just easier to do it that way. I would replace mines but i never dropped a trans alone before so im not gonna try. and my dads to busy to help me . once i get some cash in imma let someone do it for me
Old Jun 11, 2011 | 09:06 PM
chris015's Avatar
buy me a plan ticket and a 12 pack and im on my way!
Old Jun 11, 2011 | 09:10 PM
Lol i would
Old Jun 11, 2011 | 10:18 PM
Thanks for the replies. I guess I'll just keep heaving on it!
Old Jun 12, 2011 | 09:40 AM
TZFBird's Avatar
TZFBird is on a distinguished road
Do you have the oil drained? If os just stand it up on end since the transfer case adaptor will keep it up off the tailshaft. If not, skip that part.
To remove the seal, go around it with a putty-knife and a small hammer. Gently tap the putty knife in between the seal and the pump cover (after you've removed the retaining clip). Once you get the 1/16" gap or so created by the putty knife, you can go at with with a flathead screwdriver. Using a twisting, slowly work the seal out by going around the seal and twisting more as you go. You may need to go to a larger screwdriver near the end.
Installing is a pain but once you get a method down it's not so bad. Be sure to look at the condition of the bushing in the pump cover. It's just behind the seal. That will wear out and cause the converter to drop thus giving you the leaky seal. So while you're at it check that as well.
Old Jun 13, 2011 | 09:42 PM
Default Got it!
So I used a drum brake tool to get behind the gasket, and bent the heck out of it. Then I used pliers and it popped out.
Tony H
Dec 5, 2011 08:08 AM
kennycraze
Apr 19, 2011 06:25 AM
kevinph
Dec 28, 2010 07:43 AM
alesv
Apr 12, 2010 11:21 AM
shooter2499
Feb 4, 2008 09:23 PM
