how oil pressure works
1998 4.3 shell 10w30~im wondering how the switch gets its pressure reading and from where. i know where the oil pressure sensor is located, but is it an oil passage or is it reading somewhere else. also i read that its a diaphram style, so i assume it just pushes the diaphram in and it gets its reading that way, is this true?
also how do worn engine bearings effect the readings? also what else can cause low/fluctuating oil pressure. a failing pump is obvious...and possibly the oil filter/weight of oil used.
im more more curious than i am worried right now, but sometimes at idle/warm motor, the needle will flicker between say 18 and 20psi pretty jittery, but for the most part it sits steady at 18 or 19psi(fully warm engine) while cruising the highway its a hair under 40psi. and while slowly accelerating its 40-42psi.
now this is a longshot and i might get laughed at, but can a rear main seal leak contribute to lower oil pressure? i guess no, but thought id ask since its oil leaking....
I'm aware that stock oil gauges are not the greatest, and that gm says 8 or 10 psi/1000rpm
In my opinion your pressures are fine as you said. That's what mine is reading on the guage as well.
Spectreblazer
Mar 15, 2010 11:16 PM
davidsv8mustang
Feb 18, 2010 02:29 PM
Ak95Blazer
Jan 7, 2009 06:56 AM
