-   -   humming noise gas pedal (https://blazerforum.com/forum/engine-transmission-35/humming-noise-gas-pedal-80695/)
Ashblack59 07-26-2013 04:02 PM
There is a humming noise coming from my gas pedal it seems to go away when i press the pedal. It is constantly humming and vibrating. i need suggestions on where to start. ThaNKS
Ashblack59 07-26-2013 04:06 PM
Its a 96 chevy blazer vortec 4.3
Ashblack59 07-27-2013 07:32 PM
it also started stalling when at a complete stop any suggestions would be helpful thanks
chris015 07-27-2013 07:36 PM
is it like a fuel pump hum? My friend has a noise in the pedal and it was the wheel bearings echoing into it. if its stalling,check fuel pressure with a fuel kit (at autozone etc,its free with retail deposit,ask about the loan program) its gotta be 60 at key on,and hold for 10 min.
Ashblack59 07-28-2013 01:09 PM
It is not like the him of the fuel pump thanks fire the suggestion the serpentine belt came off the other day but is still intact it really didn't start humming that bad until a couple days after it was put back on could it possibly have something to do with that
Ashblack59 07-28-2013 01:10 PM
stupid auto correct
abig84 07-30-2013 06:15 PM
check your throttle cable under the hood to make sure its not resting on anything. ive actually seen them rest against the pcv valve which will cause a humming noise inside the truck
