-   -   Hvac vacuum line location forward of firewall? (https://blazerforum.com/forum/engine-transmission-35/hvac-vacuum-line-location-forward-firewall-103062/)
Uudfourty 02-25-2021 12:29 PM
2000 2wd 4 door.
Tried the search, very helpful but not telling me exactly what I need.
The vacuum line off the bottom of the T by the brake booster is nowhere to be found. It is supposed to pass through the firewall. #33 in the schematic.
Where should this hose come through the firewall? I see where it goes through on the aft side of the firewall under the dash, it is a rigid black plastic line.
Nowhere to be found forward of the firewall.
Broke off perhaps? Is it rigid all the way to #33?
If so, it looks to go through above and to the left of the transmission. Seems...unfortunate.
christine_208 02-26-2021 02:18 AM
What year do you have? And do you have the 3-button or 4-button transfer case?
See the link in my signature for more information on replacing the vacuum lines that should have other information that could help.
Uudfourty 02-26-2021 12:37 PM
I updated the original post. 2000 2wd, no xfer case. I looked over your well-done post on replacing lines. Thank you.
I believe my HVAC line is missing from the firewall forward up to the tee.
Uudfourty 03-23-2021 03:00 PM
Not finding it.
looked up around the firewall for a rigid black line leading to the HVAC. Can someone direct me to an approximate location or things nearby? Is it tied in with a wire bundle?
LesMyer 03-29-2021 10:14 AM
Originally Posted by Uudfourty (Post 732736)
Not finding it.
go to 3:08 in this video. The red line he has here turns into black line and goes back through the dash between the wiper motor and the fender. Pay no attention to the adapters he has put on this vacuum system.
LesMyer 03-29-2021 10:31 AM
Here's a better one. Factory setup and routing with snapped black plastic line for HVAC. See post 2 here:
Small plastic vacuum line? Need help please. - Blazer Forum - Chevy Blazer Forums
Uudfourty 04-15-2021 12:27 PM
Yes!
Yes! This is what I was looking for. Many thanks!
