I have no speedo or odometer!
I have recently had some work done to my 1998 gmc jimmy 4d and now the speedometer or the odometer doesnt work! the mechanic replaced the transmission. i checked for a blown fuse, but all were good.
Could there be a connection loose or forgotten to be put back together? Thanks for the help. |
Probably forgot to connect the VSS sensor. It is located in the tail housing on the transmission (2wd) or transfer case (4wd).
