A.I.R. Pump & Parts Help!!!!
new pump going in, but have a part question,, the hose leaveing the pump, runs into a T,, then branches to each side of the engine,
any idea what that T is called, and how I would explain to the parts store what I need?!?! |
3 Attachment(s)
THIS PAGE should have all of the part numbers listed out for you to repair the 'T' as well as the other parts of the air injection reaction plumbing. I believe that item #19 is what you are looking for.
Here is the image from the page: https://blazerforum.com/forum/attach...ine=1356964899 The part number is as follows: #19 - 10105352 #16 - 10217106 often goes bad as well and two are required. I have also uploaded a full page screenshot of the webpage I linked to at the top just in case that site ever goes down and someone needs to get some of the other part numbers from that assembly view that were given. |
Thank you,,, that was perfect!!! Just what I needed!
