-   -   Ignition lockout switch (https://blazerforum.com/forum/engine-transmission-35/ignition-lockout-switch-41883/)
jack215 Mar 8, 2010 05:31 PM
My 97 blazer sometimes will not start until I jiggle the shifter handle. Where is the park/nuetral ignition lockout switch
swartlkk Mar 8, 2010 08:07 PM
The park/neutral switch is on the side of the transmission. But I doubt that is the problem. If giggling the shift lever allows it to start and it is a column shifter, your problem is likely a failing ignition switch.
jack215 Mar 9, 2010 05:04 PM
It is a floor shifter, It seems like when it does this there are no instrument lights, warning ring or anything until I move the shifter.
swartlkk Mar 9, 2010 06:13 PM
Even more reinforcement that the ignition switch is at fault. A park/neutral switch issue will have no impact on warning lights, instrument cluster, etc.
jack215 Mar 14, 2010 04:48 PM
Replaced the ignition switch, works great. Thanks
1997 red blazer Mar 14, 2010 05:11 PM
Yeaaaaaaaa, Another Happy Member, Thanks to the Great Help on Here. Glad to Hear because most of the time Members Never tell us their problem is fixed or Resolved and we are left in "Hummmmmmmm" hope that worked for them ? Great to Know. Thank you for the INFO, This helps other Members Also.
swartlkk Mar 14, 2010 07:18 PM
Glad you got it fixed!!
1997 red blazer Mar 15, 2010 01:27 PM
Well after I reread what I had wrote, I can see you thinking I had the same problem, But no I was Just Happy for the OP and their Success. Thanks to you Kyle.
swartlkk Mar 15, 2010 01:59 PM
I was responding to the OP.
1997 red blazer Mar 17, 2010 09:03 PM
Ok My Mistake
Ok My Mistake, I think ? There was two replys glad you got it fixed,, but only one now ? Must Be seeing things :) T.J.
