Injector Balance Test
I finally got around to doing the injector balance test on my '99 Blazer. Took a little while to get the Tech 2 32mb card/software (originally bought the Tech 2 for my '04 Saab Aero).
The initial pressure was at 60psi, but when the pump shut off, it dropped a few psi; assuming the lower number is the correct one to record. I let it sit for 30-45sec before pulsing the injector to see if there was any pressure drop. I'm assuming a leaking injector would show a pressure drop pretty quickly. Cyl 1 58psi 42psi 2 58psi 42psi 3 58psi 43psi 4 58psi 42psi 5 58psi 42psi 6 58psi 42psi Not sure how these numbers compare to the engineered specs. Are these close, or right on?? I also performed the cylinder power balance test which showed no misfires after 10-15min of idling, and for the heck of it tested the IAC, which seemed to work as it should when increasing/decreasing by 25rpm. |
| All times are GMT -5. The time now is 11:32 AM. |
