Intake Gaskets
I have a 1995 chevy blazer 4x4 vin w i just bought a set of felpro intake gaskets and they look differnt they ports on them are cut out complety instead of being seperated they still good to use they say they fit a 95 blazer part # MS95832 i dont know how to post pics on here but heres a link to the ones i got http://www.autozone.com/N,15300526//...eResultSet.htm
RE: Intake Gaskets
GasketMS95832 gasket set is correct for a 4.3L engine, Vin W.Both water passages are open on each gasket andhave two intake ports with acommon opening.
Gasket MS933461 gasket set is correct for a4.3L Engine, Vin Z. Onewater passage is closed on each gasket andhave two intake ports with acommon opening. The water passages are the only difference. |
| All times are GMT -5. The time now is 09:18 AM. |
