Intake Manifold Bolt?
Old Oct 28, 2019 | 07:06 PM
mr.vls's Avatar
Default Intake Manifold Bolt?
I am installing an Edelbrock Intake manifold on my 89 S16 Jimmy. I am in the process of blasting all the bolts and brackets. Should I paint the intake bolts? Should I use thread sealant on the bolts? I have the Factory service manual and it does not mention using thread sealant on the bolts or around the water ports on the heads. My thoughts is to use thread sealant on the bolts for the water jackets and coat the remaining bolts with a coat of oil. Once I have all the bolts torqued to specification I would than spray clear coat on the exposed bolt heads. Any recommendations will be appreciated.
castiglian
Sep 13, 2014 04:39 AM
strmtrpr91
Nov 30, 2013 04:37 PM
Zachlee08
Oct 13, 2013 08:34 PM
gmbwrenchn
Jun 9, 2012 01:10 AM
uri
Apr 5, 2007 11:05 PM
