Blazer fuel pressure problem??
Old 04-13-2011, 06:45 PM
Bhahn25's Avatar
Bhahn25 is on a distinguished road
Default Blazer fuel pressure problem??
So I have a 2000 chevy blazer and it had trouble starting because it was not holding pressure inthe lines but I just put a new fuel pressure regulator in and fixes the problem. But my question is I hooked the gauge up and in reading at idle 50psi and it runs to 60.(50/60). And it holds 45psi in lines which is about right because you want around -5 psi holding but as far as I know blazer are suppose to run 60/66. Does anyone know what they run at and if 50/60 is right? Also, with the key on the pump gets 60psi
Old 04-13-2011, 06:50 PM
*Thread Closed - Double Post* - Please wait for a response in the thread you already posted this question in.
Jesse31
04-06-2015 03:23 PM
RodneyB
02-12-2015 08:13 PM
cramcam
17
07-11-2013 08:32 AM
jsmurphyphone
12-29-2011 02:33 PM
Spartan66
07-11-2008 02:34 PM
Quick Reply: Blazer fuel pressure problem??
