k5 Trans lines
does anyone make Pre Bent Transmission lines for a 87 k5 blazer? thanks aj
I believe that LMC Truck has them. I would recommend buying line and bending it yourself though. It's fairly easy to do especially with the right tools (hand held bender, cut/flare tools, etc). Starting with some fairly thin project wire to get the length & bends down before messing with the line itself makes it easier as well.
| All times are GMT -5. The time now is 09:03 AM. |
