leaking lots of coolent
i cant find a bad hose the systum is bone dry right now and im at work so cant add water till lunch to see where leak is coming from and its my DD X-( puss its 27° out thining radeator is ther nething els i shode check. p.s. i no im a ****y speeler srry
Do you have a rough idea where its at...pass side...driverside?
Heater core hoses on top of engine pass side.....waterpump? Location and rate that your losing coolant would help out |
passenger side leak was coming from under the front skid plate near radiator.coolent was coming out rilly fast and a lot at 1s
it was to dark for me to see when i poped the hood |
sounds like the water pump you might wanna remove the plate to check it
its doesent have a ruff idel but i did see water coming from the muffler :-(
do u guys think it could be a intack manifold?!?
water from exhaust can be condensation.
intake manifold, it can leak coolant outside the engine, and it can burn some coolant. find the leak fast, because if coolant is getting in the oil, it will ruin your bearings... btw, im canadian, i speak french, and i can write better than you. please make an effort, this is no text messages. |
well im not driving it now its going to be towed to a teck for work. and it was way more then just condensation coming out
| All times are GMT -5. The time now is 08:58 AM. |
