-   -   little rough (https://blazerforum.com/forum/engine-transmission-35/little-rough-30328/)
M4RKETT1 05-07-2009 03:48 PM
little rough
my 95 LT blazer has a very annoying rough idle issue. when stoped, it's very jittery going up and down in RPM's, and it idle's bad. any ideas?
oisinirish 05-07-2009 03:52 PM
HA...Several.
When was last tune-up? Plugs,Wires, Dist. Cap.
Cleaned EGR?
Cleaned TBI?
rriddle3 05-07-2009 03:58 PM
We've had lots of posts about rough idling. Have you read them to see some of the ideas and solutions?
swartlkk 05-07-2009 06:18 PM
Vacuum leaks? Dirty/stuck IAC valve on the throttle body?
M4RKETT1 05-07-2009 06:27 PM
thanks, only the sparks :\
i have the cap, just havn't did it yet.
will be getting wires.
and replacing EGR.
cleaned tbi? what is tbi, no the smartest here.
swartlkk 05-07-2009 07:32 PM
I think he meant TB (throttle body) since you have a CPI motor.
M4RKETT1 05-08-2009 07:50 AM
don't mean to sound stupid, but how would i go about cleaning my throttle body?
swartlkk 05-08-2009 07:56 AM
With some sensor safe carbon cleaner and a brush. The TB is not removable on the CPI motor.
oisinirish 05-08-2009 08:04 AM
DOH!...yep.
M4RKETT1 05-09-2009 07:35 PM
UPDATE: during yesterday driving, it got worse. when i was stopping and i got around 10mph/lower. if i stopped braking, and braked again they would get stiff as if the car was off and i was just pumping, it got to the point where i couldn't even push my pedal! but it seemed to relieve pressure when i gave it gas. also while accelerated, it seemed as it was going to die, get around 1500RPM's and it's bog for a sec and then speed up.
