'89 Blazer - No Start, weak spark
Old 09-28-2010, 07:41 PM
'01zr500's Avatar
'01zr500 is on a distinguished road
Default '89 Blazer - No Start, weak spark
I have an 89 blazer 350 that will not start. I use it as a plow truck to plow my 1000' driveway clear of lake effect snow. (She pushes way better than any Ford.)
What I have verifed.
Cap and Rotor are good. Plugs are good. (New Last Year)
Grounds are clean (pain in the A$$ and time consuming)
I am getting fuel at the carb.
She will not start with start fluid.
Spark is weak. (Yellow)
I have changed in order listed:
New Gas
Igniton coil
Ignition Control Module (New)
What am I missing?
Snow is coming and I am getting anxious. (I live south of Buffalo, NY)
Old 09-28-2010, 07:50 PM
abig84's Avatar
kinda a long shot but look up your tailpipe, if the truck has been sitting all year maybe something crawled up there and died blocking the exhaust.
after cranking it a while pull a out a plug to see if its wet then you know fuel is getting into the truck.
try cranking with the cap off, possible broke timing chain?
old trucks are pretty simple. if its got spark and gas itll run
unpredictable1
24
01-10-2016 10:22 AM
Crestwood1001
06-02-2009 09:02 PM
patterrr
10-24-2006 03:50 PM
blazinloud
Engine & Internal
10-17-2006 05:39 PM
Quick Reply: '89 Blazer - No Start, weak spark
