-   -   Loss of power on 95 Blazer 4.3L (https://blazerforum.com/forum/engine-transmission-35/loss-power-95-blazer-4-3l-81598/)
Piero Sep 13, 2013 10:06 AM
Hello,
There is a problem on my Blazer now, it miss power ! The V6 roars, the transmissions works good, but no power...
Engine light is OFF.
I don't know where it could come from. Does anybody had a similar problem here ?
Piero Sep 13, 2013 01:10 PM
Oh, I've forgot to say my catalitic converter is noisy.
AndrewO1991 Sep 13, 2013 05:43 PM
when my fuel pressure regulator started leaking i had very poor power, i also got 10mpg and black smoked real good at start-up. Usually a clogged cat wont let the engine rev high, i say usually just becasue there are always exceptions.
toyhauler1283 Sep 13, 2013 07:46 PM
I had a similar issues on my 98 s-10 pickup the cat clogged up so bad even downshifting and flooring it the truck would barely move. So I unbolted the cat and started it up and ran fine so I knew it was the cat . Without exhaust flow it won't run.
Piero Sep 14, 2013 02:03 AM
Ok, tomorrow I'll unbolt the cat and empty it, and test.
Piero Sep 15, 2013 12:34 PM
1 Attachment(s)
I've dismantled the exhaust today. This is what there was inside the cata !
https://blazerforum.com/forum/attach...ine=1379266448
Some of these blocks of ceramic were inside the muffler... I think this is the cause of my loss of power.
I'm gonna do some welding... and put the empty cat on the car...
Piero Sep 17, 2013 05:43 AM
What do you think about an empty catalytic converter with 2 oxygen sensors ?? Does the engine work properly ?
AndrewO1991 Sep 17, 2013 08:25 AM
engine will operate fine, you will get a check engine light with your downstream sensors saying catalyst efficincy below threashold, or something like that. You definatly wont pass emissions.
Piero Sep 17, 2013 12:49 PM
And if I unplug the second sensor and put it on a support outside the cat... ?
Piero Sep 24, 2013 03:29 PM
I've tried with the sensor on and out the exhaust, it's almost the same. And no CEL. It just miss torque because my cat is empty.
I've tested my emissions on a gas analyser, the lambda is good , 1.02 .
