MAF Sensor
Quick question-
If I unplug the MAF sensor, should the engine cut off? Tried it for a test and it made little difference in the idle. The reason I did it is I'm having a p0101 issue I'm trying to track down. Thanks in advance for y'alls input. |
https://blazerforum.com/forum/diagno...plained-31561/
See the diagnostic charts in this link. You will need a scanner and a multimeter to diagnose your MAF sensor. |
Originally Posted by Lesmyer
(Post 681771)
See the diagnostic charts in this link. You will need a scanner, a multimeter, and a hand vacuum pump to diagnose your MAP sensor. |
Originally Posted by GreenBlazer2002
(Post 681777)
I scoured the search function on here and never came across that link. Thanks man!
| All times are GMT -5. The time now is 09:47 AM. |
