Manual swap help/info
Hey everyone, I've made quite a few posts about my Blazer however this one is at the top of my list currently. I have a 95 Blazer 4x4 and want to do a manual swap. I know the transmission should be a NV3500, now I need to know where i can get all the parts, i.e clutch, slave, pedel, crossmember and drive shaft to do this swap or if there is a cheaper swap. I really miss driving a stick. Thank you in advance.
I've also read something about a T56 swap but is that even for a 4x4? |
Lotta work. Probably looking at wire harnesses, dash brackets, PCM reprogram or one from the donor vehicle, etc, etc. Boneyard would be the place to start looking.
Do you recommend doing the B&M shift kit instead?
If you're looking for shift points to be a little more "crisp", upgrading to a Corvette servo might be what you're looking for: https://blazerforum.com/forum/engine...20/#post646299
Thank you
| All times are GMT -5. The time now is 12:25 PM. |
