-   -   Manual transfer case engages itself-Any Ideas? (https://blazerforum.com/forum/engine-transmission-35/manual-transfer-case-engages-itself-any-ideas-48918/)
southernsteel87 Sep 9, 2010 11:19 AM
Every time I stop quickly (1987 K5 Blazer) I get a grinding/whining noise coming from the transmission, and no movement, it can't get into gear. I have to turn the motor off, move the lever to 4Lo, put it in park, start the motor(no more grinding), shift to neutral then back to 2WD. Not fun to do in the city. Motor mounts and tranny mounts look good.
swartlkk Sep 9, 2010 11:22 AM
Your transfer case is dropping into neutral. Which transfer case do you have? Look at the tag on the back of the transfer case.
southernsteel87 Sep 9, 2010 11:29 AM
Np-208
swartlkk Sep 9, 2010 11:42 AM
You could try to adjust the linkage, but if the truck has high mileage, the pads on the shift fork inside could be worn to the point of needing replacement. I have seen a few where the pads were worn completely away and the fork was starting to wear. This required a complete replacement of the fork.
Drivetrain.com has an NP208 page that has an exploded view. They also carry the mode and range forks. I believe that the range fork is what controls the neutral shift, but you will have to open it up to see which ones are bad. Hopefully you only need the pad kit if it needs to go that far.
southernsteel87 Sep 9, 2010 12:06 PM
Thanks for help I'm going to order that fork today, never taken apart a transfer case before , do you know if I need any special tools or can I just make do with what I can find in my garage.
swartlkk Sep 9, 2010 12:12 PM
Found by doing a google search for "NP208 Rebuild"
http://members.cox.net/fsjntechstuff...eDiagnosis.PDF
http://members.cox.net/fsjntechstuff...nchFixture.PDF
http://members.cox.net/fsjntechstuff/NP208Rebuild.PDF
southernsteel87 Sep 9, 2010 12:38 PM
Dude you are amazing, you saved me so much time, this is going to be a piece of cake.
J-Adix Oct 23, 2010 10:23 AM
Same Boat
Hey guys
My '83 is doing the same thing, I've also never rebuilt a transfer case before. I ordered a rebuild kit, and both forks (I just figured I'll replace 'em all while I'm in there), once they get here I"ll start tearing into it. Got any tips?
Josh
