maybe i can use some help
Old Aug 28, 2013 | 08:31 PM
95vortec4.3's Avatar
95vortec4.3 is on a distinguished road
Default maybe i can use some help
so my 99 blazer will not turn on at all it will crank and crank but it just wont turn for some reason what can it be?? or what should I look for
Old Aug 28, 2013 | 08:39 PM
Flipside's Avatar
Flipside is on a distinguished road
Look to see if you're getting fuel, can you hear the fuel pump whine when you turn the key on? Last tune up? Plugs? You need fuel, air, and spark to run an engine.
Old Aug 28, 2013 | 08:59 PM
just replaced all of that this past Monday except the wires, did replace the fuel filter and nothing theres times where I crank it and it wants to start but it wont like if shes not getting enough of something & have to check the fuel pump
Old Aug 28, 2013 | 09:10 PM
Flipside's Avatar
Try squirting a little starting fluid in the intake, if it starts then its a fuel delivery problem.
Old Aug 28, 2013 | 09:28 PM
thank I will do that as soon as possible & heres a lil video of what I exactly mean
Old Aug 31, 2013 | 11:18 AM
Jaylo's Avatar
Jaylo is on a distinguished road
Could b a fuel pump problem or an ignition module problem. What trouble-shooting codes r u getting?
Doctorvette
Nov 5, 2012 11:57 PM
xgiovannix12
Performance & Brainstorming
Jul 29, 2011 07:39 PM
cleanmantim777
Nov 17, 2009 08:35 PM
USMaverick101
Nov 17, 2006 04:06 PM
jadewolf32
Mar 1, 2006 02:48 PM
