Misfire or 4Lslippye?
Old Sep 23, 2024 | 10:12 PM
1996POS's Avatar
1996POS is on a distinguished road
Default Misfire or 4Lslippye?
Hello I just picked up a 96 blazer 4wd with 189k today and on the way home I noticed that the car did not like going above 3k rpms, the car has a p0134 code (bank 1 sensor 1) and a small evap leak code. I put the pedal to the floor and the car shifted which makes me believe its not a transmission issue. I am extremely new to the 4.3 platform so any advice would be greatly appreciated.
Old Sep 24, 2024 | 12:09 PM
GeorgeLG's Avatar
Monitor your scanner fom a cold start in the morning and tell me if the behavior is any different when it warms up and transitions from open loop to closed loop fuel control. If it transitions.
What are your 4 fuel trim numbers
You need to do the fuel pressure test in the sticky
George
JK72VC
21
Aug 2, 2023 09:17 PM
kempo
Jun 1, 2019 11:31 PM
GreenBlazer2002
19
Dec 8, 2017 04:20 PM
Sk8Jitsu
Aug 16, 2009 02:16 PM
96Ls4Dr
Jan 3, 2008 09:03 PM
