Missing
All right guys this is my first thread so bear with me....
2001 Blazer...134,000 Miles on it and it's missing bad We had a slight antifreeze leak so we changed the radiator took care of it for a few days then all of sudden massive leak. Here the intake gasket blew. So we actually took on the task of replacing it...went smooth actually but we started it and now it misses very bad. We replaced spark plugs, wires cap and rotor...Thinking it's a injector but we didn't touch them. Any Ideas?!?!? Thank You! |
Have you checked to make sure that the distributor is timed properly?
Ok I'm going to sound stupid for a min but I'll ask any way...how do I check that?
By clicking on the link found in my post above. :icon_wink:
Originally Posted by JamieSue
(Post 395199)
2001 Blazer...134,000 Miles on it and it's missing bad We had a slight antifreeze leak so we changed the radiator took care of it for a few days then all of sudden massive leak. Here the intake gasket blew. So we actually took on the task of replacing it...went smooth actually but we started it and now it misses very bad. We replaced spark plugs, wires cap and rotor...Thinking it's a injector but we didn't touch them. Any Ideas?!?!? Thank You! A. |
1 and 3 wires are tricky. I almost swapped them by accident myself.
That side of the Distributor is 3-1-5. |
Originally Posted by cbr995
(Post 396578)
That side of the Distributor is 3-1-5. To the OP: Did you sort things out?? Thanks! A. |
We thought that we had the wires backwards but nope they are all ok. Had a guy tell me to try Marvel...Any of you guys hear about it?
Check the gaskets on the upper intake manifold. The gasket around the throttle body can be especially tricky. If it's sucking too much air in, that will cause it to misfire. I've had this happen to me twice with my 99.
(Post 397613)
A. |
| All times are GMT -5. The time now is 04:26 AM. |
