Missing
Plugs seem fine we changed them 3 times in the few months. What a pain to get to the one on the side. Any way I guess Marvel is a solvent a guy told me that if it's dirt causing the miss it'll disolve it
I'm assuming you didn't buy the $135 AC delco wires, which is fine, but the cheaper wires aren't as good. I bought el cheapo wires for my tune up over break and I had a massive miss. The miss set a P300 code which is random misfire(if I have the code right) I chased everything and it ended up being Cyl 1 & 3 wires were touching just a bit causing a Crossfire. It's hard to see the routing of the wires given how crampped it is on that side. Make sure they arent touching at all. Also if you do have a miss check for codes it could be localized(say Cyl 3) due to a cracked plug wile trying to put the new one in.
Anyway, I digress... Good luck on the fix. Do you hear even the faintest 'tick.. tick... tick' when the engine is running and you listen under the hood? If so, something is shorting to ground somewhere in the spark line.
A.
Ah ha! Now we're getting somewhere.... No! You shouldn't hear a hissing noise under the hood. Take a piece of hose (garden, utility, fuel, whatever) and put one side to your ear, and dangle the other side (carefully!) under the hood to track down the noise. If you have propane or carb cleaner even, give a few shots around intake gaskets, pcv and intakes, etc. If you can get the motor to rev, you have found your leak. Check the brake booster, intake and pcv locations first and god luck! A leak big enough can cause a no start depending on if it's causing unmetered air, etc. Let us know how you make out. It could be a cracked hose also....
A.
A.
