Motor wont turn and fuel pump wont kick in and have no dash dummy lights
I have a 95 s10 blazer that wont start. The battery is up and i have power to everything but the engine(starter)and the fuel pump. The dummy lights on the dash dont light up when i turn the key either.It dont click or anything. It's a 4 door with a 4.3 automatic.Please help!!!!
RE: Motor wont turn and fuel pump wont kick in and have no dash dummy lights
try checking your fuses?
did the fuse fix your problem?
If not try replacing the battery wire to the starter. and check your connections at the starter. |
| All times are GMT -5. The time now is 09:53 AM. |
